Greetings Everyone
I love Photofiltre and have been using it since V6 to create graphical tribute to WW2 troops of Australia.
So much simpler than Photoshop and quite powerful.
However, I made the uneducated mistake of saving my tributes in JPEG format initially.
Mistake because as I found out just recently everytime I edited or amended one the colors started to fade a little due to recompression every time.
I have over 2,000 images that I wish to revive the colors off and have found (as a gneral comment) the revive colors function does a good job.
However to do over 2,000 manually is just not productive.
So my question is IN BATCH MODE
1. can I use the revive colors filter OR
2. can someone suggest another package to do so to the same approximate settings that Photofiltre uses OR
3. can you tell me what setting Photofiltre uses to o "revive colors" i.e saturation etc etc etc
Thank You
Ray
Batch Processing with REVIVE Colors
stormtigers
- Version de PhotoFiltre : 7
- Processeur : i7 Pentium
- Mémoire RAM : 16gb
Re: Batch Processing with REVIVE Colors
the revive color is just a saturation (+). Try with an image to have the best adjust
stormtigers
Thank you saturation between 10-20% seems to do the trick nicely.
