idea
jashleygraphics
- Habitué(e)|Habitué|Habituée
- Version de PhotoFiltre : 10.14.0
- Processeur : acer
- Mémoire RAM : 2 gb
idea
good morning, I'd like to propose one thing but I don't know if it's feasible, actually more things.
What if there were two versions for each version of Photofiltre studio? a 64 and a 32-bit? Another thing but if the partial saturation was put in the menu "levels" -> Adjustments -> Hue/saturation ? It's just an idea.
Re: idea
Non, comme je l'ai déjà dit, il n'y aura plus de mise à jour de la v10 (studio X). Et pour la version 11, je n'ai ni l'envie ni le temps de gérer 2 versions (32-bits et 64-bits), donc ça sera seulement une version 64-bits, en plus tous les PC sont maintenant 64-bits donc le 32-bits va devenir obsolète.
Re: idea
why did you want 64-bits version of plugins if you can use 32-bits version with PhotoBridge on PhotoFiltre 11 ?
same 32-bits plugins can be used by PhotoFiltre Studio X and PhotoFiltre 11, it's better no ?
jashleygraphics
- Processeur : acer
Re: idea
" Another thing but if the partial saturation was put in the menu "levels" -> Adjustments -> Hue/saturation ? It's just an idea. "
jashleygraphics
- Processeur : acer
Re: idea
no all the filters I noticed are not going. Those of 8bfAntonio a écrit :why did you want 64-bits version of plugins if you can use 32-bits version with PhotoBridge on PhotoFiltre 11 ?
jashleygraphics
- Processeur : acer
Re: idea
as well as having brightness, contrast, hue, basic saturation if you add in layers.jashleygraphics a écrit :good morning, I'd like to propose one thing but I don't know if it's feasible, actually more things.
Hue and saturation by changing channels?
jashleygraphics
- Processeur : acer
Re: idea
It would be convenient, because you can save them in PFI format so as not to repeat the options manually in other photosAntonio a écrit :for me it's better to put with grayscale, swap color, gradient, ... because it's a color filter not really an adjust filter
jashleygraphics
- Processeur : acer
Re: idea
Maybe it's always an idea you could add the option to choose the color in level -> adjustments
jashleygraphics
- Processeur : acer
Re: idea
not even adding a new feature? that is, all programs have the ability to create files in layer format where there is only one color and the rest in black and white
