Messages : 12771 Inscription : 28 oct. 2003 22:49
Message
par Antonio » 28 janv. 2022 11:03
of course it's cosmetic, the whole interface is cosmetic, the yellow button is cosmetic too
But for the moment I don't change this background, on the one hand because I personally like it and on the other hand I want a standardized display whatever the style.
6Hokage
Messages : 19 Inscription : 05 oct. 2009 23:46
Version de PhotoFiltre : Studio
Processeur : --
Mémoire RAM : --
Message
par 6Hokage » 28 janv. 2022 20:14
There are several styles that are completely different even down to close/expand buttons.
Why can't there be a style with the old layers look.
Message
par Antonio » 28 janv. 2022 22:24
Not for the moment, if you want old style, you can continue using Studio X, the main difference is 32-bit vs 64-bit.
Message
par Antonio » 29 janv. 2022 11:27
I had to fix a display bug today in
Windows 11 styles. Download again if you use these styles
viewtopic.php?f=15&t=23289
Message
par Antonio » 19 févr. 2022 18:30
new korean langage file
Message
par Antonio » 11 juin 2022 10:37
new language files Swedish, Ukrainian & Russian
viewtopic.php?p=185544#p185544
minniechihiro20
Messages : 15 Inscription : 30 janv. 2022 14:06
Message
par minniechihiro20 » 07 oct. 2023 16:34
Sorry 11.5.0 download virus?!?
Message
par Antonio » 07 oct. 2023 19:04
of course no, antivirus like bitdefender allways detect false positive because they don't want to fix it !
