About PhotoFiltre 11 beta (64-bits)
jashleygraphics
- Habitué(e)|Habitué|Habituée
- Version de PhotoFiltre : 10.14.0
- Processeur : acer
- Mémoire RAM : 2 gb
The Italian translation does not work, it opens in French :O
Is it because still in beta or what?
jashleygraphics
- Processeur : acer
Re: PhotoFiltre 11 beta (64-bits) / utilisateurs avancés
photofilter plugins don't work either
french only for the moment, no translation available.
==> of course, plugins and 8bf must be 64-bits too, and for the moment non plugin in 64-bits
jashleygraphics
- Processeur : acer
Then I'll wait, I love photofilter and I'm sorry if I can't use the 11
Re: About PhotoFiltre 11 beta (64-bits)
if it is to use 32-bit plugins, you don't need PhotoFiltre 11 64-bit, it is better to keep version 10 32-bit
The 64-bits version is for uses who work with big images and lot of layers, and need all memorry available
jashleygraphics
- Processeur : acer
but will there be a new version for 32 bits? or will it just be the 10th? Sorry to ask but since I love Photofiltre, its 32-bit plugins and more I would like to continue updating it
no I don't think, but version 10 is already complete and don't need to continuing to develop it, except if it has important bugs
jashleygraphics
- Processeur : acer
So too bad for now a 32-bit 11 version is not?
Maybe some new plugins for the 10 example partial saturation and save it in PFI format? I know I break ahaha
jashleygraphics
- Processeur : acer
Update 32 or 64 bits release ?
Excuse me there will also be a version 32 or only 64? It would be a shame to have photofiltered studio updated.
Re: Update 32 or 64 bits release ?
No, PhotoFiltre 11 is now unicode and the V10 (studio) are not unicode. If i create a 32-bits version of PhotoFiltre 11, it will be unicode too and plugins/translation will not work no more. In this case 32-bits version are not needed, it's better to use the current Studio. I know it's not easy to understand if you are not dev...
The problem is not 64-bits/32-bits, it's Unicode (16-bits charset) / Non unicode (8-bits charset)
jashleygraphics
- Processeur : acer
How did you say 8bf filters don't work but if you solved the problem with I was photoshopping a DLL or creating a folder for the 8bf at 32Bit? Can?
for the moment, you absolutely need 64-bit 8bf but there are some on the net (harry's filetrs, mehdi, ...).
On the other hand, the nick collection 64-bits do not work with the 8bf host that I use
jashleygraphics
- Processeur : acer
Quiet! In fact I have confidence in this program and I will be patiently waiting for new updates
marekx
Well done.
I use PF for many years now, and have licenced PF Studio X on my linux desktop PC.
I've just tried PhotoFiltre 11 beta on my linux PC (Mint 20.1, 64bit) using wine and it works OK.
There were some system or program errors during starting process but they seem to be not critical.
If it can be any help I copy and paste them:
$ wine PhotoFiltre11.exe
it looks like wine32 is missing, you should install it.
as root, please execute "apt-get install wine32"
wine: created the configuration directory '/home/gajowy/.wine'
0012:err:ole:marshal_object couldn't get IPSFactory buffer for interface {00000131-0000-0000-c000-000000000046}
0012:err:ole:marshal_object couldn't get IPSFactory buffer for interface {6d5140c1-7436-11ce-8034-00aa006009fa}
0012:err:ole:StdMarshalImpl_MarshalInterface Failed to create ifstub, hres=0x80004002
0012:err:ole:CoMarshalInterface Failed to marshal the interface {6d5140c1-7436-11ce-8034-00aa006009fa}, 80004002
0012:err:ole:get_local_server_stream Failed: 80004002
0014:err:ole:marshal_object couldn't get IPSFactory buffer for interface {00000131-0000-0000-c000-000000000046}
0014:err:ole:marshal_object couldn't get IPSFactory buffer for interface {6d5140c1-7436-11ce-8034-00aa006009fa}
0014:err:ole:StdMarshalImpl_MarshalInterface Failed to create ifstub, hres=0x80004002
0014:err:ole:CoMarshalInterface Failed to marshal the interface {6d5140c1-7436-11ce-8034-00aa006009fa}, 80004002
0014:err:ole:get_local_server_stream Failed: 80004002
Could not find Wine Gecko. HTML rendering will be disabled.
wine: configuration in L"/home/gajowy/.wine" has been updated.
0009:err:listview:LISTVIEW_WindowProc unknown msg 109d wp=00000000 lp=00000000
Good luck with further development!
thanks for testing
I think IPSFactory errors comme from the 8bf host dll (8bf_64.dll in the folder Plugins)
