Choose the pattern of transparent background
giona888
Version de PhotoFiltre : 10.14.0
Système d'exploitation : Windows 10 Home
Processeur : Intel(R) Core i7 7700HQ
Mémoire RAM : 8 GB
Message par giona888 »
It would be nice to add this feature, so I can choose between the default graphic checkerboard "white and gray" or one-color background (gray, black, red, green, etc.)
I often edit white text graphic with alpha channel and is hard to see properly the textes because the default checkerboard "white and gray" pattern.
Still this software is very nice. :clap:
Re: Choose the pattern of transparent background
not possible but you can insert a new color background (menu Layer > Insert new background) and choose a color to contrast with your font color. Before saving, don't forget to hide the background to save only the first layer (not the background)
giona888
Mémoire RAM : 8 GB
Thank you for this trick Antonio. I will try!
