Create a simple mosaic
Onktebong
Version de PhotoFiltre : 7
Système d'exploitation : Windows 8.1, 10
Processeur : AMD E-450, AMD Ryzen
Mémoire RAM : 8 GB
Message par Onktebong »
Hi, I would like to create a backdrop for a video conference, and for this is want to create a collage or mosaic of the same logo repeated several times.
I know how to do this with copy-and-paste but it's difficult to keep the logos aligned.
Is there a simpler way to do this?
Merci beaucoup! :D
Re: Create a simple mosaic
Hi, the issue is in the menu Edit : Define pattern on the logo
and Fill with pattern on the target sheet.
