Styles
Re: Styles
don't understand, a sample ?
jashleygraphics
- Habitué(e)|Habitué|Habituée
- Version de PhotoFiltre : 10.14.0
- Processeur : acer
- Mémoire RAM : 2 gb
Re: Styles
Example these, save the style in PFI format and you can use it in another pc without putting settings.
https://images-wixmp-ed30a86b8c4ca88777 ... 103daa.png
Re: Styles
you have some text effect in the Text option. You can find lot of tutorials on the net and you tube :
see this page (in frensh)
http://www.photofiltre-studio.com/tutolinks-en.htm
jashleygraphics
- Processeur : acer
Re: Styles
Yes, but can you save the effects in PFI format in some way to use on another computer?
Re: Styles
no, you must redo the effect for each pfi
jashleygraphics
- Processeur : acer
Re: Styles
it would have been nice instead of not doing it again, I will look forward to new updates
