Gradient
jashleygraphics
Version de PhotoFiltre : 10.14.0
Processeur : acer
Mémoire RAM : 2 gb
Gradient
Message par jashleygraphics »
Hello I wanted to know if it was possible to save the gradient filter gradients in a folder or is there another filter?
Re: Gradient
the plugin gradient or the native photofiltre filter ?
jashleygraphics
Processeur : acer
Mémoire RAM : 2 gb
Re: Gradient
I was asking if it was possible to save the gradients created with the filter "Gradiente.PL" in a folder or not?
jashleygraphics
Processeur : acer
Mémoire RAM : 2 gb
Re: Gradient
Re: Gradient
don't know this filter, it's a plugin 8BF ?
jashleygraphics
Processeur : acer
Mémoire RAM : 2 gb
Re: Gradient
I tried to search but at least I didn't find anything
