Hi from Brazil
claudyarizhman
Version de PhotoFiltre : 10.14.1
Mémoire RAM : 4GB
Hi from Brazil
Message par claudyarizhman »
I have installed the last version of Photofiltre today in zip format. I launch the program, but I have one question and one issue:
1) I am using Windows 8.1 here, where can I save the zip file of Photofiltre? In folder C: programs>64 bits? Or C: programs>32 bits? I installed it in the Download folder by now
2) After clicking the icon and open the program, I try to open my image at some of my images folders. But, bellow on the left side, all images of that folder start to open in thumbnails. And, Photofiltre says a message error, that the software isn´t responding anymore. How can I stop Photofiltre to load all images when I open only one image from a certain folder?
Thank you/Merci :mrgreen:
Re: Hi from Brazil
hide the image explorer (menu Tools > Image explorer)
you can unzip anywere, for exemple in c:\photofiltre
