Diacritics
Rustik
Version de PhotoFiltre : 7
Système d'exploitation : Windows 8.1
Processeur : i5-3570
Mémoire RAM : 8 GB
Diacritics
Message par Rustik »
Hi! I need to use Spanish letters with diacritical signs (accents), like á,é, ó, ú, í, ñ when I'm adding a text to the image. But none of diacritics appears. I also tried to insert them using "Table of symbols" button in Options window but the there is no effect. I also downloaded and installed PhotoFiltre Studio X but there is the same bug. Could you help me please? Thank you beforehand!
Re: Diacritics
PhotoFiltre don't supports 16-bits charset only 8-bits. But you can enter the text on WordPad and copy/past to PhotoFiltre as an image
Rustik
Mémoire RAM : 8 GB
Re: Diacritics
Antonio a écrit :PhotoFiltre don't supports 16-bits charset only 8-bits. But you can enter the text on WordPad and copy/past to PhotoFiltre as an image
Thank you!
