Hello - sorry, I don't know if this is the right forum area. I can read French, but I can't write it.
Having used PF6 and PF7 Portable in the past, I downloaded PF7. I see there is a folder browsing window at the bottom of the screen, which takes up screen room, and I can't find any obvious way to close it. Can it be closed?
Thanks.
Window at botton of screen in PF7
haegri
- Version de PhotoFiltre : 6.5.1 + 7
- Système d'exploitation : Win 7
- Processeur : AMD Phenom II X4 970e @ 3500MHz
- Mémoire RAM : 4096MBDDR3-SDRAM
Re: Window at botton of screen in PF7
menu Toosl > Image explorer
haegri
Merci beaucoup! C'est facile quand on sait comment!
