plugins
caterino70
plugins
Message par caterino70 »
Hello!
To my necessities, this is a very good program, but still, I don't know why there is no way to curve words
this lack is a pretty good problem to me
Windoline
Re: plugins
Message par Windoline »
Hi Caterino70, you should use the software Gimp to curve words, it's free and like Photoshop
Greetings you !
Re: plugins
Windoline a écrit :Hi Caterino70, you should use the software Gimp to curve words, it's free and like Photoshop
Oui bon... on est tout de même sur le forum de PhotoFiltre. :roll:
caterino70 a écrit :Hello!
.../... I don't know why there is no way to curve words .../...
For a smal curve you can try Menu / Layer / Transform / Curve, or in a selection :
Menu / Filter / Deform / Curve or Twirl
For text around a selection, You can use the plugin "Paste inside" with the option "around"
Other effects with the plugin "Deformation" and very interesting ones with the 8BF "Pinocchio" from,"MV's Plugins"
And if you don't find your luck you can use Word Art or FontWork (Libre Office) and Copy Paste.
viewtopic.php?p=123526
viewtopic.php?p=137404#p137443
