PFSX 10.0.14.1 not responding after open any ./Textures file
VictorVG
Version de PhotoFiltre : 8, 9.x, 10.x
Système d'exploitation : Win7 SP1 x64
Processeur : Intel i7-2600 / z68 / NVIDIA GTX 1060 3Gb
Mémoire RAM : 16 Gb DDR3-1600 9.0-9-9-24 Cr2
Message par VictorVG »
OS Win7 SP1 x64
Only PFSX v10.0.14.1 not responding after open first graphics file in to ./Textures or ./Patterns dir, but if this file located exclude PFSX dir then not problems:
For control I use Process Hacker (currently use v3.0.7680.3153 Git-90e5fee1, v3.0.7687.3160 Git-eb30ec96 I compiled, but not checked) in . mini-window (placed in tray):
in process, propitiates, Performance tab:
In to Threads tab:
P.S.
A friend brought this version, said that it hangs and asked to check his observations. Checked, yes he is right, and the phenomenon, although under specific conditions, is observed.
I apologize for my English and if I mixed up the forum section.
Re: PFSX 10.0.14.1 not responding after open any ./Textures
Some freeze under XP too, i restored the old version 10.14.0 because for the moment i don't find the bug :cry:
i can reproduce the bug when using old style dialog box. If i use the vista style i can open image, it's the same for you ?
can ou test this beta ? it's slower because i disabled jpeg thumbnail mode, i think the bug is in the thumbnail
http://www.photofiltre-studio.com//tmp/ ... x_test.zip
VictorVG
Test pfstudiox_test.exe is success if I open any images in to ./Textures or ./Patterns dir I can open any other images. But if I use pfstudiox.exe old in display I see:
and see Statistics tab:
Priority, 8
Cycles, 397 394 988 000
Cycles delta, 3 404 380 575
Kernel time, 00:01:47.578
Kernel delta, 9 360 060
User time, 00:00:08.720
User delta, 624 004
Total time, 00:01:56.298
Total delta, 9 984 064
Private bytes, 12,63 MB
Private bytes delta, 0
Peak private bytes, 25,83 MB
Virtual size, 186,12 MB
Peak virtual size, 218,81 MB
Page faults, 52 305
Page faults delta, 0
Working set, 153,22 MB
Peak working set, 153,3 MB
Private WS, 11,67 MB
Shareable WS, 141,55 MB
Shared WS, 25,24 MB
Page priority, Normal
Reads, 29 630 200
Reads delta, 256 611
Read bytes, 3,47 MB
Read bytes delta, 0
Writes, 1
Writes delta, 0
Write bytes, 116 B
Write bytes delta, 0
Other, 5 356
Other delta, 0
Other bytes, 57,6 MB
Other bytes delta, 501,2 kB/s
I/O priority, Normal
Handles, 293
Peak handles, 354
GDI handles, 238
USER handles, 184
Paged pool bytes, 353 kB
Peak paged pool bytes, 387,58 kB
Nonpaged pool bytes, 30,39 kB
Peak nonpaged pool bytes, 35,28 kB
Running time, 00:00:00.000
Context switches, 0
Total Dedicated, 0
Total Shared, 0
Total Commit, 0
Reads, 0
Read bytes, 0
Read bytes delta, 0
Writes, 0
Write bytes, 0
Receives, 0
Receive bytes, 0
Receive bytes delta, 0
Sends, 0
Send bytes, 0
Send bytes delta, 0
and have process dump - https://www.upload.ee/files/11942751/pf ... p.zip.html (used WinDbg format)
I think it's fixed with this release :
http://www.photofiltre-studio.com//tmp/pfsx10141.zip
VictorVG
I test latest beta with SHA-256 (pfstudiox.exe) = 2b20a70e4e2c785f30e13927b7f7d0951ecb03a695379d28cbe72effdf9c5305 - all images is open success, problems is resolved.
Big thanks!
Also a gift from me - Process Hacker v3.0.7689.3162 Git-06964b9f ​​pre-release (latest):
The documentation is as I have in the repository - for this you need to download the source ZIP / BZip2 and Git itself will generate a snapshot of the last commit on the fly, and on the project website. The only thing that, in addition to setting the settings, you will need to enable the Advanced setting and put in the settings editor:
<setting name="EnableKph">1</setting>
<setting name="EnableKphWarnings">0</setting>
## KProcessHacker
Process Hacker uses a kernel-mode driver, KProcessHacker, to
assist with certain functionality. This includes:
* Capturing kernel-mode stack traces
* More efficiently enumerating process handles
* Retrieving names for file handles
* Retrieving names for EtwRegistration objects
* Setting handle attributes
Note that by default, KProcessHacker only allows connections from
processes with SeDebugPrivilege. To allow Process Hacker to show details
for all processes when it is not running as administrator:
1. In Registry Editor, navigate to:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\KProcessHacker3
2. Under this key, create a key named Parameters if it does not exist.
3. Create a DWORD value named Security Level and set it to 2. If you are
not using an official build, you may need to set it to 0 instead.
4. Restart the KProcessHacker3 service (
sc stop KProcessHacker3
sc start KProcessHacker3
because To make it possible to translate into Russian, my assembly does not have a signature, but the KProcessHacker*.sys kernel drivers are signed by the developer.
Dernière modification par VictorVG le 29 juin 2020 16:24, modifié 2 fois.
thanks will test it :wink:
VictorVG
Mutually!
There is only one question left - how would I update the Russian translation? Part - in terms of documentation, I did a long time ago, but the .plg library is partially outdated and contains under-translated strings. I couldn’t find the guys, especially Adept, although he and I once translated The KMPlayer - he made the literary edition of my technical translation and I think that for PFS X it is possible and it is necessary to clarify the obviously outdated translation, but I do not have basic templates for this, although I can do the translation in my specialty, I am a systems engineer for computers, computer structures and networks.
i will check the last russian file and post it here
VictorVG
Ok!
Here is the last russian translation. Translate the words at the end of the .pas file. Use ansii char only because PhotoFiltre is non unicode. When translated, send me the .pas file, i will compile it to create the .plg file.
http://www.photofiltre-studio.com//tmp/StudioRU_pas.zip
VictorVG
Big thank! Download it. I think in an hour - I’ll complete a half-ready translation on GitHub - so it will be more convenient for us to modify it if necessary. I have a special repository there https://github.com/VictorVG/Source where I will share the source code - both the backup copy and it’s more convenient to work.
VictorVG
Ready. Commit up to GitHub - StudioRU.pas
PhotoFiltre Studio X 10.0.12+ Russian translation
* Update translation for version 10.0.12+
* Fix some typo
SHA-256
973e96ce9195e05813664255af7b0418a33c5c639f85fbffd8508c5261ef5302 *StudioRU.pas
uploaded and updated my download page :
http://www.photofiltre-studio.com/download-en.htm
