PF Studio Problem
Bill
Version de PhotoFiltre : Free and Studio
Système d'exploitation : Coffee
Processeur : God Given Brain
Mémoire RAM : Not as well as when I was younger
PF Studio Problem
Message par Bill »
This happens if I am using the Alpha-blend Dialogue Boxes
Windows XP Pro
Latest drivers
ATI RADEON X800 XT
Pent 4 3.6 G HT
2 gig of ram
See Images Below:
When I use the Swap RGB / Posterize or Duatone Tools if the tool window is on the image and I apply the tool what is under the tool is not processed like the rest of the image.
echo0001
Version de PhotoFiltre : 6.1
Système d'exploitation : Windows 98
Mémoire RAM : 64mb
Message par echo0001 »
That's very strange....
I'm sorry I can't back you up here; I did not have the same problem with PF Studio....
But, I have had a similiar problem with another program. This may not help you one bit, but you never know..... When I encountered a similiar problem with the other program, if I went to full screen view of the image, the part that had not processed 'became' or was shown processed, and when I returned to the program window the image was properly processed. This probably won't help, but I thought I would mention it....
yes it's a bug, but a Windows XP bug for me because windows don't refresh background before displaying an alpha-blending dialog box !
In the other filter, i force manually a refresh before displaying the dialog box but i forgott this for this 3 dialog boxes :oops:
I will fix this in the next version :wink:
Bill
Message par Bill »
Antonio:
It's really not that much of a problem. I have 2 choices. Move the tool window before I apply the filter or do not use the alpha-blend boxes. I just thought I would let you know.
Now on to problem #2. Who is going to walk me through the French Pay-Pal screen. My trial is running out and I just redid my PhotoFiltre Tips'n Tricks site so I could have Studio Tutorials to.
I think PayPal supports multi language ?
MightyKitten
Version de PhotoFiltre : 6.1.1 NL / 7.0.1 NL
Système d'exploitation : Windows XP Pro/SP2
Processeur : Pentium IV @ 2,66 Ghz
Mémoire RAM : 704 MB
Message par MightyKitten »
Antonio a écrit :I think PayPal supports multi language ?
Normally, yes, but on your account, it supports only french, I'd understand.
Paypall does not support any language by the way. Dutch for example is not supported.
As for a not too good, but workable solution: http://babelfish.altavista.com could help you trans late the page (and give you some laughs at te translation, in the same time)
Jeroen
