I was using photofiltre as usual when suddenly the eraser tool seems to have broken down. Instead of erasing things, the eraser tool suddenly started working as a strange white brush that roughly paints behind any other shapes.
https://i.gyazo.com/1b7ead32e38f5459871 ... da5453.png
[Tom] I replace the image by the link. The size exceed the rule of this forum (800 x 600 pixels) [/Tom]
I've tested this with both a completely transparent things, things with partial opacity and opaque things. The eraser completely destroys any transparency on anything it gets brushed over, and doesn't erase anything opaque at all anymore. How do I fix it?
Eraser Tool Not Working
Awa303
jashleygraphics
- Habitué(e)|Habitué|Habituée
- Version de PhotoFiltre : 10.14.0
- Processeur : acer
- Mémoire RAM : 2 gb
Re: Eraser Tool Not Working
Décoche "revers"
Awa303
Sorry, what? I don't speak french, and google translator isn't making sense for what you've just said. What does "revers" mean?jashleygraphics a écrit :Décoche "revers"
Hi, Awa
He would probably tell : "Invert",
Under the options of the Erase tool you have to uncheck the box "Invert"
Awa303
It worked! Thank you very much, you both.
