Make PF remember size settings
chayes
Message par chayes »
hi
How can I open PF 7 with the image at 100%.?
I know how to set it when the program is open , but when i close the program , it forgets the setting.
At the moment it always opens at 67%. How can I make it always open at original size 100%?
Thanks.
Dernière modification par chayes le 28 déc. 2019 15:13, modifié 1 fois.
Re: Make PF remember size settings
not possible, allways autozoom by default
chayes
Ok that's a pity. Thanks for your help. I was hoping maybe a plug-in could do it.
