Hi,
I'm using Photofiltre 7 to take the curves out of my fish-eye images.
It's works very well, but takes a long time to find the correct
width and height settings. (Each correction takes about a minute to complete.) I'm wondering if there's some way I can assess how much adjustment I should make and in which direction (+or -) I should go?
Thanks,
........ john
Fisheye correction
Shinnen
- Mémoire RAM : 1.5 gig
Re: Fisheye correction
what function is used ? a plugin ?
Shinnen
Hi Antonio,
I'm using the Fisheye correction plugin.
... john
... john
in this case there is no auto setup, you need to test the best for each image
While you try to find your best tuning, you can uncheck "Antialias" and click on Preview to have un idea of the result.
And when your choice is done, check again "Antialias" before to click on OK.
Shinnen
Hi Tom,
I have been using 'preview' while attempting to get the right settings.
Are you saying that unchecking 'Antialias' will speed up the intermediate steps
before finally saving?
... john
... john
Yes, you can try, you will make your own point of view.
Shinnen
Thanks again, Tom and Antonio.
... john
... john
