andreasm
Message
par andreasm » 16 mai 2005 13:55
I'd like to edit gif and ico files in photofiltre. At the moment, this isn't possible.
Additional it would be great, if I could select a frame of an ico file. At the moment, photofiltre only loads one frame.
Messages : 13136 Inscription : 28 oct. 2003 22:49
Message
par Antonio » 16 mai 2005 14:10
It's already possible ! PhotoFiltre supports GIF an ICO files
Messages : 2950 Inscription : 08 mars 2004 18:17
Version de PhotoFiltre : Dernières de PF Free et PFS
Système d'exploitation : Windows XP Home SP2
Processeur : Athlon 64 3500+ non O/C
Mémoire RAM : 2x512 Mo en DC
Message
par FrançoisL » 16 mai 2005 14:53
Maybe your problem is the first question in my
FAQ ?
Andreasm
Message
par Andreasm » 16 mai 2005 14:55
Yes, I could open them... but not edit them. The paint-options in the sidebar aren't useable.
If I load a jpeg, I could edit it.
What's wrong?
Message
par FrançoisL » 16 mai 2005 14:57
OK, see my previous post
Invité
Message
par Invité » 16 mai 2005 14:58
Image/Mode/ is grayed, too.
and Image/Coulor of transparency doesn't work...
Invité
Message
par Invité » 16 mai 2005 15:01
Sorry, now it works... but it's very difficult to find it out...
couldn't you make it easier to edit files with transparency and low-colors ?
Message
par Antonio » 16 mai 2005 15:27
is for that i put it in PhotoFiltre.htm in the dirst lines
andreasm
Message
par andreasm » 16 mai 2005 15:31
What about a message, that appears, when opening files with transparency?
"This file has transparency. To edit it, you must deactive transparency. Do you want to deactive transparency now? YES/NO"
That would be very very great! and would take only a little time to program.
thanks!
Message
par FrançoisL » 17 mai 2005 18:40
andreasm a écrit : would take only a little time to program.
Not sure !
Antonio would have to set a test on each Filter ! (I think...
