Third line on top is missing
Solyong
Version de PhotoFiltre : 6.5.3
Système d'exploitation : Win 7
Processeur : Intel (R) Core (TM) i3-2120 CPU @ 3.30GHz
Mémoire RAM : 400 GB
Message par Solyong »
Bonjour.
Recently I encountered a problem with my PF. I cannot get the screenshot I made to show up here, so please bear with me when I am explaining like a DAU.
When I open up the program, there were three lines above the place for the picture. The first one is in writing (line datei/bearbeiten/ansicht etc.). The second shows icons, which by clicking on them open a menu (like size/open/save etc.)
Until some days ago there was a third line with other icons, like for instance to flip the picture or a part of it horizontal or vertical, for 90° left or right, etc.
Unfortunately this line is gone now. How can I get that back?
Thanks in advance for any help.
Best regards.
Re: Third line on top is missing
Hi, bonjour, :)
Your problem can rapidly be solved :
Open "Menu / View" and check "Filter bar".
Enjoy with PhotoFiltre.
Solyong
Gosh, can one person be so silly? Yes, I just proved it :roll: .
Thanks a lot,
Solyong
PS. Will you please mark this as solved?
