Hi,
is it possible to change the color of the inner frame around a picture?
I use a dark theme for my Windows 10 and the inner frame is in a blue Windows 7 style, so I would like to change it to a dark color too.
Here you can see what I mean, I want to change the color of the area marked with the red arrow:
https://imgur.com/a/CX5KPHd
Thank you!
Change color of inner frame around picture?
Frank8877
Re: Change color of inner frame around picture?
With last windows release it's not possible to customize theme colors
perhaps with a windows theme editor ?
Frank8877
For me it looks like that the colors (and the Windows 7-look) of this inner frame is fixed in Photofiltre.
It seems that the Windows-Theme has no effect on this inner frame.
My hope was that there is maybe a config-file or something like this in Photofiltre to adjust these colors.
==> of course no, photofiltre don't fixe windows color, windows are created only by system.
With windows 7 it's possible to change colors by setting the theme but windows 10 dibaled it now
Frank8877
Thank you for your information.
So it is a Windows 10 problem - but at the moment I have no idea how to adjust the dark theme to change the color of the inner frame too.
Now I remember using PhotoFiltre with Windows 7 (Dark Theme) and there the inner frame was dark.
Do you see a chance to make changes in PhotoFiltre to change the frame-color also in Windows 10?
Thanks!
Thanks!
You can find colors setting in the registrery, but it's not the best way to change it. Don't understand why Microsoft disabled it in last version.
\HKEY_CURRENT_USER\Control Panel\Colors
I don't tested change it directelly in registrery, don't know if it works...
Frank8877
Now I checked those color-settings in the registry for my dark theme.
All the colors in this registry-path are set to grey and black colors as I expected for my dark theme, strangeley enough there is no light blue color (like in the inner frame of PhotoFiltre) in these registry-settings.
Additionally I checked all my system colors with the tool "Classic Color Panel" -> also no light blue color.
At the moment I'm clueless - has anybody an idea how to change the color or style of this inner frame?
I think windows disabled these registrery values, it's for that it' s not possible to settings in the advanced display prameters
see this link :
https://superuser.com/questions/949920/ ... d-in-win10
see this link :
