Unable to save image in file
tyhely
Version de PhotoFiltre : 10.14.0
Message par tyhely »
Hi, i have problem with saving images to secondary hdd (D:)
When i open small image put some effect then simply save so i get this error "Unable to save image in file D:\IMAGES\...." when i do this same with location located on disk C all is ok..
Photofiltre version 10.14.0, Windows 10
Re: Unable to save image in file
Wiindows 10 locks external drive for lot of applications. Try to run PhotoFiltre in admin mode but not sure it will work. It's better to save to local folder before and move it with explorer
tyhely
Antonio a écrit :Wiindows 10 locks external drive for lot of applications. Try to run PhotoFiltre in admin mode but not sure it will work. It's better to save to local folder before and move it with explorer
It is internal drive.. run as admin and grant folder permission for "everyone - full control" nothing solve..
This is only one of apps that did sth like that..
photofiltre don't control nothing, only call windows api. If the system send an error when saving to D and not to C there ara some reason. Perhaps the file name, a special char or a spacing in the name ?
tyhely
Antonio a écrit :photofiltre don't control nothing, only call windows api. If the system send an error when saving to D and not to C there ara some reason. Perhaps the file name, a special char or a spacing in the name ?
nothing special.. http://502.cz/scr/TeamViewer_2019-08-25_21-06-53.png
D is an hard drive or a usb stick ?
tyhely
Antonio a écrit :D is an hard drive or a usb stick ?
is internal harddrive at sata port
can you try to rename '01.jpg' to 'image01.jpg' (put a letter before the number)
