The string "Opening" is used more then one place
scootergrisen
Message par scootergrisen »
Is this string being using both on the status bar and in preferences drop down list?
TrStaOpening = 'Opening';
In danish language it is not translated correctly both places.
So i suggest adding something like:
TrLblOpening = 'Opening';
So i can translate it seperately.
Re: The string "Opening" is used more then one place
it's not possible to separate translation because it's only one string in my code.
The correct translation is "Opening (image)"
