How to make a signature ??
Lincon
Message par Lincon »
Hello everyone,,
I'm new here and I need your help ....
I'm looking for a signature I know he already had someone who showed how on a video but I can not find that c?
and anyway she or he goes too fast would there be a place that explains how we do ??
Thank you for answering me
Re: How to make a signature ??
Hi Lincon,
there are many ways to insert a signature, as much as you can imagine.
- The simplest way : menu Image / Copyright.
- To insert a graphic one, add a transparent layer : menu Layer / New / Blank, and check "Automatic transparency"
then you can draw or paste any image you want. You can also "Export the layer" (in layer menu) as Png image for re-using it
You can also, by this way, apply the Png image with the "Automate" tool at an images collection.
A tutorial to use the PngData Module :
http://www.photofiltregraphic.com/02pre ... otopng.htm
TinyAlien
Version de PhotoFiltre : 7.2.1
Processeur : Pentium D
Mémoire RAM : 3Gb
Message par TinyAlien »
The easiest way I have done this is by making an advanced paintbrush 'brush'. This is simply a black and white square (maybe 256 x256) PNG file that you place in the Photofiltre/brushes folder and then use the advanced brush, select the signature and click anywhere to 'sign'. This is also how people make signatures in Photoshop as well. :wink:
Lincon
Thank you my issue has been solved,.....
