When I've used PF Studio for a while and then leave it, my screen saver comes on. When I want to come back to using PF Studio, all the past dialogs I've used appear on the screen in succession. Finally I get the program. This doesn't happen with the old PF.
Has anyone else had this happen? Should it be this way? Why are these dialog screens still in memory? Does that rob memory from editing?
I've taken to shutting PF Studio down after each photo I edit. I don't know if this helps, but I figure it might cut down on what's im menory.
Is this a problem, or should I ignore it?
Jim
Problem?
- Membre d'honneur
Jim Clatfelter
no screen shot
Yes, it happens every time.
I can't get a screen shot using PrtScr. The underlying program comes up on the screen shot. The PF dialog boxes don't come up. If PF Studio is the last program used, it comes up on the screen shot, but the image and the layers images are black. When it runs through all the dialogs, PF Studio appears with the images.
JiIt can take several seconds to display all those old dialog boxes.
Jim
Jim
- Membre d'honneur
