How do I remove white outline around my sprite?
pearl84
Message par pearl84 »
I'm making a simple HTML5 game.
I had a sprite. I removed the background from this sprite using the "transparent background" option in Photofiltre. I do not have any other photo editing software.
I managed to remove the background from the sprite. Unfortunately, my sprite has a whitish outline around the figure. This outline is especially noticeable when my sprite is placed over dark backgrounds on the web page. white border around sprite [no_advertising]
I was wondering how other people deal with this problem?Thanks!
Dernière modification par pearl84 le 04 mai 2019 13:49, modifié 1 fois.
Re: How do I remove white outline around my sprite?
when you erase the background, did you disabled Selection antialiasing ?
what is trnsparency depth ? 8 bits, 24 bits or 32 bits ?
can you post a sample ?
TinyAlien
Version de PhotoFiltre : 7.2.1
Processeur : Pentium D
Mémoire RAM : 3Gb
Message par TinyAlien »
One trick you can try is to first select the layer with the sprite on it.
Then in the menu select Selection, then select layer. You should now have a highlighted selection around the sprite also called marching ants.
Then click Selection again then select Contract, then choose a width, if you are not sure just choose 1 pixel. Then press ctrl+I to invert the selection, then click delete on your keyboard. This should remove a 1 pixel outline around the sprite. You can do this any number of times. If you made a mistake simply undo or press ctrl+z to undo.
