Middle Mouse Button = Hand
Yuki
Message par Yuki »
¿Es posible utilizar el botón del medio del ratón como un atajo para la herramienta de la mano?
is possible to use the middle mouse for a hand tool shortcut?
Re: Middle Mouse Button = Hand
no, middle click not supported, only middle mouse wheel for scrolling
TinyAlien
Version de PhotoFiltre : 7.2.1
Processeur : Pentium D
Mémoire RAM : 3Gb
Message par TinyAlien »
Learn to use the keyboard shortcuts instead.
The shortcut for Hand tool is U, so simply typing U on the keyboard will get the tool automatically. The if for example you then need the brush tool simply type P. This is a simpler way and its how the pro's do it.
Willcox
Message par Willcox »
Can you change the keyboard shortcuts to anything you like or are they locked?
TinyAlien
Mémoire RAM : 3Gb
In Photofiltre 7 they are pretty much locked.
