Hello everyone. I was working on .pfi file in Photofiltre X (ver.10.8.1) and after a certain point I tried to reopen the file and now an error pops up saying "Erreur de lecture du flux". From what i understood from some google searching is that the file got too big/complex and now Photofiltre is not able to open it anymore? Is there a way to open or recover it in some way (maybe in another software)? It a was an image file with 200+ layers in which i put a lot of work into and it would be a shame if I lost everything : /
Thank you in advance!
Photofiltre X .pfi file opening error "Erreur de lecture du
Re: Photofiltre X .pfi file opening error "Erreur de lecture
your file is corrupted, you don't create a copy of this image ? you should allways have a copy because compressiona of lot of layers can corrupt the memory whan saving.
Try to open with PhotoFiltre 6, to open only the layer 0 (merged)
this error is for corrupted file. it's because memory crashed when you saved it the last time
Il you have not other copy, it's not possible to open with layers.
You can try to open with PhotoFiltre V6 without layers
It is necessary to create copies of your work, not only with photofiltre, with all softwares...
