PFS x v10.13.1 not reading certain filters 8BF
sigi08
Message par sigi08 »
Hello,
in PFS X v10.10.1 there are much more filters loaded than in version v10.11.0 or v10.13.1 (latest version).
for examples Andrew's filters.
The same unpacked filter map is used/linked. Both pc's have W10 v1809.
A workaround would be to install PFS X v10.10.1. Is there a way to download the original version v10.10.1?
Thanks for your help.
Sigi
Re: PFS x v10.13.1 not reading certain filters 8BF
this is not photofiltre filters but 8BF plugins. This plugins are installed separatly. You intalled it manually with your version 10.10 and forgot it now :wink:
Mészáros Tamás
Version de PhotoFiltre : PhotoFiltre Studio 10.13.1
Système d'exploitation : Win 7 Home Premium SP1
Processeur : AMD II X2 Athlon 265 3.3 GHz
Mémoire RAM : 8 Gbyte DDR3 2133 MHz Predator Kingston RAM
Message par Mészáros Tamás »
sigi08 a écrit :Hello,
Sigi
http://www.cybia.co.uk please test this plugins. Copy ..\plugin folder... this is me ok...
Best Regards:
