- Fixed moderator status removal in groupcp.php
- Removed newlines after ?> on some files - Thoul
- Added admin re-authentication (admin needs to login seperatly to access the ACP) - backported from Olympus
- Fixed vulnerability in url/bbcode handling functions - PapaDos and Paul/Zhen-Xjell from CastleCops
- Fixed issue in admin/admin_forums.php
- Suppressed warning message for fsockopen in /includes/smtp.php - Thoul
- Fixed bug in admin/admin_smilies.php (admin is able to add empty smilies) - Exy
- Adjusted documents to reflect the urgent need to update the files too (not only running the database update script)
- Updated the readme file
- Added one new language variable
- Added general error if accessing profile for a non-existent user
- Changed session id generation to be more unique - Henno Joosep
- Fixed bug in highlight code to escape characters correctly
- Reversed the 2.0.14 fix for postgresql because it produced more problems than it solves.
- Added reference to article written by R45 about case-sensitivity in postgreSQL to the readme file
- Fixed bypassing of validate_username on registration - Yen
- Empty url/img bbcodes no longer get parsed
phpBB 2.0.15
Heis Spiter
- Mémoire RAM : 1536 Mo DDR
phpBB 2.0.15
Nouvelle mise à jour.
Heis Spiter
Heis Spiter
Heis Spiter
- Membre d'honneur
Heis Spiter
- Membre d'honneur
