In Windows 7 control panel uninstall there is no icon for Photofiltre X. Just a generic icon.
Also there is no info in published by, size and version.
So maybe this could be added to the Windows installer.
Missing info in Windows uninstall
Modérateurs : Modérateurs, Développeurs
scootergrisen
- Habitué(e)|Habitué|Habituée
ShaneO
Re: Missing info in Windows uninstall
Probably you have or any other software has already removed it. Do a restart and check if its there or not then try to clean it from the registry and reinstall again.
Regards,
Shane.
Regards,
Shane.
ShaneO
DID it work? Please confirm and say.scootergrisen a écrit :In Windows 7 control panel uninstall there is no icon for Photofiltre X. Just a generic icon.
Regards,
Shane.
scootergrisen
Its still the same.
Do you have the info in Windows 7 control panel uninstall?
no change for the moment...
