Please 16:9 selection on photofiltre 7
Saphotoxu
Version de PhotoFiltre : 7.2.1.
Processeur : Intel I3
Mémoire RAM : 8GB
Message par Saphotoxu »
Hello!
I've been using this for years to edit pictures. :) :)
Very good. (Photofiltre 7)
Selection Crop ratio now: 1:1, 2:3, 4:3
It would be a great help possibility to cut the "16:9" ratio.
Thank you!
Re: Please 16:9 selection on photofiltre 7
you can use the menu Selection > Ratio :wink:
Mechanic
Version de PhotoFiltre : Adobe Photoshop CS5
Processeur : Intel(R) Pentium (R) CPU 987@ 1,50 GHz 1,5 GHz
Mémoire RAM : 4 Gb
Message par Mechanic »
Saphotoxu a écrit :Hello!
Thank you!
I also ran into this issue. I tried to solve this problem through the menu Selection> Ratio, but nothing happened. Maybe there is still some way?
_________
use the menu Selection > Aspect ratio > 16:9 to fit the ratio to 16:9
