Using hue variation
Pumpkin Universe
Using hue variation
Message par Pumpkin Universe »
I have two almost identical images, one mostly green and one mostly pink. I want to make the mostly pink one to be mostly green, but I don't want any green, I want something as much close as possible from the green image (actually I want to have the same green).
If I use hue variation tool, I can drag that bar and chose some green, but my problem is that I want the specific green that is on the another image.
Is it possible to pick the specific color and apply it as a "source" to the hue variation on my pink image?
Re: Using hue variation
You can use the Filter > Color > Green for example and adjuste after with Hue and saturation.
You can use a color layer too for more colors...
jashleygraphics
Version de PhotoFiltre : 10.14.0
Processeur : acer
Mémoire RAM : 2 gb
Message par jashleygraphics »
I tried to use adjustment - > but when you go to choose the color dan change via "Channel" you can not change the color you change all
try the function Adjust > Replace color range
jashleygraphics
Processeur : acer
Mémoire RAM : 2 gb
In photofiltre 10 or 11? Sorry screen ?
both !
jashleygraphics
Processeur : acer
Mémoire RAM : 2 gb
Tried but if I want to lower the saturation of that color?
i don't know exactelly what you want to do.
In PhotoFiltre 11 only, try Filter > Color > Partial desaturate
jashleygraphics
Processeur : acer
Mémoire RAM : 2 gb
I liked to create coloring PFI including partial saturation, I will try photofilter 11, for now translation in Italian is not there?
only english
