background after cut and paste
Shinnen
Processeur : Intel p4 2800mhz
Mémoire RAM : 1.5 gig
Message par Shinnen »
Hi,
I'm using Photofiltre 7 to cut and paste a circular fisheye image. I would like the area around the image to be white or black or some solid colour. As it is I have a checkered pattern there, which I'm guessing I can colour, but don't know how. Any help is appreciated.
Thanks,
.... john
Re: background after cut and paste
1) select the center part of your imagre
2) Invert selection (right click in the selection)
3) Use the menu Edit > Fill & Stroke (CTRL+B) and fill only
Shinnen
Hi Antonio,
Worked like a charm.
Thanks,
..... john
Shinnen
Hi Antonio,
When I posted my original question I was using Photofiltre to cut a circular image from a fish eye photo; but then I tried the spheric option in Photofiltre, and WOW, what a difference. Please accept my compliments. This function does a BEAUTIFUL job.
Is this feature intended to produce fisheye effect?
Thanks again,
..... john
not exactelly a fisheye but a fisheye like :wink:
Shinnen
Thanks.
.... john
