Would you like to know if it is possible to convert a select
talitawy
Message par talitawy »
Good Morning!
Would you like to know if it is possible to convert a selection to vector in photofiltre studio?
Well, I want to use the style option of the part (cotorno and fill) of the vector in a font.
Thanks. :mrgreen:
Re: Would you like to know if it is possible to convert a se
Hi,
right clic in the selection / Manual settings is the simplest way.
You can also try menu Selection / Expand or Contract.
There is no direct tools to transform a text bitmap selection in a vector one.
But you can get a correct result in bitmaps mode and refine evently
with the aliasing tools or menu / Layer / Border effect
