How to Remove Wrinkles in Photofiltre 7?
worksforce
Message par worksforce »
Hi
Regards
Theo
Re: How to Remove Wrinkles in Photofiltre 7?
Hi
I will reponse in the evening.
  • First i smooth basicaly the most defects of the skin with the smudge tool and a low pressure
  • Select the surface you want to smooth with the selection tool as lasso or polygon and set antialiasing as Progressive contour.
    You need to avoid to select eyes, mouth, the contours of the nose, in order to keep personality of the subject
  • Add noise (menu Filter/Noise/Add noise) Amount between 20 and 30
  • Menu Filter/Noise/Dust reduction : Amount 50%, Radius between 3 ans 6, Color checked
It is not necessary to smooth too much the skin to keep a natural appearance. A low level of noise is better than an iced face.
Example : (left clic to enlarge)
Edward_Terry
Message par Edward_Terry »
It turns out that's how you can do it quickly.
