Scanning multiple documents
Invité
Message par Invité »
It is only possible to scan one document and then te scanning software (Twain) is closed by Photofiltre. You have to restart for each document the scanning software. Can it be made possible to start once the scanning sofware and scan more then one document?
No, only with scan that support this function.
