I've just began using PhotoFiltre Studio V9 and I'm having a problem figuring something out.
When I'm building a design in layers, often I do something that seems to lock the layers. I know there's a right-click option to lock them, however I seem to be doing something else that I can't figure out what.
Is there a way to unlock the layers once they've becom locked?
Anybody have any ideas what causes the layers to lock, other than selecting that option? )Perhaps an accidental double-click outside of the image or something?
Thanks in advance.
I didn't find the right solution from the Internet.
References:viewtopic.php?f=21&t=17469
[Tom] I mask the link to a page without relation with the subject [/Tom]
donnieclark
Re: PhotoFiltre Studio V9
Dont' know exactelly what is for you "locked" ? for moving, drawing, ...?
To move a layer (for exampole), you must activate the layer tool in the tool palette. If you activate pencil or select tool, you can not move a layer.
