Minimum filter doesn't work as expected
lcm
Message par lcm »
In Photofiltre, Minimum filter works like Median filter in Photoshop.
To get an expected result, I can use NegativeMaximumNegative, but it's too long and obscure.
Re: Minimum filter doesn't work as expected
what version of PhotoFiltre ? did you tryed with the V7 ?
lcm
Message par lcm »
PhotoFiltre v6.5.3 works as expected. However, there are only three settings of radius (Low-Medium-High).
PhotoFiltre v7.2.1 and PhotoFiltre X 10.11 (just tried) works as shown in the first post.
i will check source because i think it's a bug
I checked my source and found the bug. It will be fixed in the next release (in april i think)
Jonathanzz
Version de PhotoFiltre : Jonathanzz
Système d'exploitation : Jonathanzz
Processeur : Jonathanzz
Mémoire RAM : Jonathanzz
Message par Jonathanzz »
Thanks for the reply.
