How to make photo spheres
Doc O'Neill
Message par Doc O'Neill »
Can you do polar coordinates in Photofiltre?
If so how?
Re: How to make photo spheres
Hi,
you have to search on the web a pack of 8BF filters, which is named "Distort" and contains
a 8BF filter "Polar coordinates".
With PhotoFiltre 7, for use this 8BF filter you need to instal the Plugin "8BF Filters" from this page :
http://www.photofiltre-studio.com/plugi ... ins-en.htm
For a best result you need to prepare the image as the left and the right side would be connected
without visible cut.
you can try Fillter > Deform > Ellipse. Not exactelly the same result...
