Scanner Canon MP280
webmaster.
Version de PhotoFiltre : 10.10.1
Processeur : intel i7
Mémoire RAM : 8 gb
Scanner Canon MP280
Message par webmaster. »
Canon MP280:
preview = ok
scan = NO (sistem bloked)
Grazie
webmaster.
Re: Scanner Canon MP280
check first if you have the last twain drivers for your scanner
webmaster.
Mémoire RAM : 8 gb
Sono aggiornati. Il problema dello scanner non riconosciuto da Photofiltre mi si presenta da anni, prima con Lexmark, poi con HP, ora con Canon.
Se viene riconosciuto in fase di anteprima, perchè non viene riconosciuto quando deve scanerizzare? Grazie
Webmaster.
Updated. The problem with the scanner is not recognized by Photofiltre presents itself to me for years, first with Lexmark, then with HP, now with Canon.
If it is recognized in the preview stage, because it is not recognized when it has scanerizzare? Thank you
Webmaster.
Mise à jour. Le problème avec le scanner est pas reconnu par Photofiltre se présente à moi pendant des années, d'abord avec Lexmark, puis avec HP, maintenant avec Canon.
Si elle est reconnue à l'étape de prévisualisation, car il est pas reconnu quand il a scanerizzare? merci
Webmaster.
webmaster.
Mémoire RAM : 8 gb
Nessuno è in grado di aiutarmi?
Personne ne peut me aider?
No one is able to help me?
Webmaster.
sorry but no solution for the moment :cry:
I know there are this bug with some scanner but don't know why...
webmaster. a écrit :.../...
Webmaster.
When you try to use your scanner from the PhotoFiltre application, you think your work as a pull action,
intend to get back the image from the scan. Ok it doesn't work as expected... :(
But you can think your work as a push action : most of scanner models have a specific sofware program which can push the result :
- some of them can transmit (or pass hand) the image result to an image-editor application, perhaps PhotoFiltre.
You have to look into the settings of the scanner software if this option do exist.
- and most of them can automatically save the image result in a folder defined in the settings. So you can also scan your images by lot,
may be in PNG or Tiff format (lost-less).
and of course you can open this folder and double clic these images to open them (push again) with PhotoFiltre
(if associated in Windows settings to this file format).
