I have been using PhotoFiltre successfully for a couple of years. Today when I went to print a jpg that I have successfully printed before, it prints a blank page. I tried two printers and also printed to PDF. All gave blank page.
I searched here and made sure Mode was RGB. I downloaded another program, Fotografix portable and it printed the image fine, so it is not the fault of the image.
What puzzles me is that I changed nothing and this just stopped working. I tried redownloading the program with a fresh install. This did not help.
I have found a work around for my current problem, but I am still puzzled why this happened.
Ed
Prints blank page
evbrown
- Version de PhotoFiltre : 7.2.1
- Processeur : Intel i5
- Mémoire RAM : 4 Gb
Re: Prints blank page
check if print mode is graphic or picture and not text and try to reduce dpi to 300
evbrown
I assume you are referring to the mode of the device, the printer? It is not the printer. As I said, I was able to work around by printing the image with another program. I tried reducing the DPI on the PhotoFilter print dialog screen to < 300 DPI. No change. It still prints a blank page.
PhotoFiltre works with most printers. I know some blank page with some laserjet printers/scanner but user can fix it changing parameters. Did you tryed to change paramaters like quality ?
==> perhaps yopu updated your printer drivers (or windows dll) ?
