Hi,
I want to resize a picture I have and paste it into an email; but when I do that the picture comes out a little blurry. Is there a way or resizing the picture while retaining the clarity of the original?
Thanks,
..... john
resizing image
Shinnen
- Mémoire RAM : 1.5 gig
Re: resizing image
Using lancszo or bicubic resample mode preserve more details. Try this when resizing but it can be different for each image
Shinnen
Re: resizing image
Thanks Antonio.
...... john
...... john
Re: resizing image
After resizing, each times i add some filter like :
- "Sharpen" to get better edges (a little bit more bright),
- but, most of the time, i prefer "Sharpen edges" to get edges a little bit more deep
Don't forget to use Edit / Fade if the result is too strong.
Shinnen
Re: resizing image
Thanks Tom. That's very helpful.
......john
......john
