Language files order
scootergrisen
Message par scootergrisen »
Should the language files on the following link not have a system, like a-z?
http://www.photofiltre-studio.com/download-en.htm
Perhaps you could write "en" "nl" and so on and sort by that.
It is easier to read then "English / English / Anglais" and "Nederlands / Dutch / Néerlandais".
Perhaps put everything in a HTML table and then you dont have to write "Translated by " and "Updated for the V 10.10+" multiple times.
You could just write it once in the header of the table.
scootergrisen
Re: Language files order
Will the languages ever be sorted?
no, it's sorted by date of creation, not by name. There are only few langage, it is easy to find :wink:
