Unicode Support
Ray Koopa
Version de PhotoFiltre : PhotoFiltre Studio X 10.9.2
Système d'exploitation : Windows 8.1 Update 1
Unicode Support
Message par Ray Koopa »
I know Delphi had a hard time with Unicode for years, but do you think you can add support for opening images from Unicode paths?
I often edit Hangul named files, and PhotoFiltre just sees question marks when opening images.
For example, 톱니바퀴_a.png just becomes ????_a.png in PFS, and then it can't even open it...
Re: Unicode Support
Delphi 7 don't support unicode, only Delphi XE but my code don't run with XE. lot of works to convert :cry:
