Making any colour transparent (if it's consistent in hue)
Rihojo
Version de PhotoFiltre : 10.8.1
Processeur : Intel Core 2 Duo E6750 266 GHz
Mémoire RAM : 3 GB
Message par Rihojo »
Hi,
Does anyone know how I can make one colour transparent? Normally, one can use the wand and clear, but for convenience (for example removing a white background where there would still be white within text even though the outer white has been cleared) it would easier to remove the entire colour.
Rihojo
Mémoire RAM : 3 GB
Re: Making any colour transparent (if it's consistent in hue
don't forget to change the tolerance (30 or more)
