It would be desirable with a larger brush size than the current 400 pixels. I think many newer computers could handle the increased load as a brush size of 600-800 pixels would.
Would it be possible to achieve such?
Best Regards
Peter
Larger brush
Petjo10
- Version de PhotoFiltre : Studio X 10.10.0
- Système d'exploitation : win 8
- Processeur : i7 -4700HQ 2.4GHZ
- Mémoire RAM : 12Gb
Re: Larger brush
800x600 is the size of my PC screen for internet
I not tested with modern PC, my last PC has more than 6 or 7 years old. Perhaps in the futur, need to test before
Petjo10
Re: Larger brush
It would be very desirable with a larger brush size, because many newer DSLR cameras are now over 20 megapixels. The current 400-brush becomes quite small.
Regards Peter
Regards Peter
Mészáros Tamás
- Version de PhotoFiltre : PhotoFiltre Studio 10.13.1
- Système d'exploitation : Win 7 Home Premium SP1
- Processeur : AMD II X2 Athlon 265 3.3 GHz
- Mémoire RAM : 8 Gbyte DDR3 2133 MHz Predator Kingston RAM
Re: Larger brush
Hi Peter!Petjo10 a écrit :It would be very desirable with a larger brush size, because many newer DSLR cameras are now over 20 megapixels. The current 400-brush becomes quite small.
Regards Peter
I do not think that someone 16 megapixels resolution for more editing at home. Grafic work now popular display IPS Full HD monitor (23"-34"). The UHD monitor rare home. High price, so not cheap.
A real photographer knows not only the extra high resolution of the secret of a good photo.
Best Regards:
