Quick Compatibility Question
b1rd
Version de PhotoFiltre : 6.2.3/ PF Studio
Système d'exploitation : Windows XP Home
Processeur : Intel
Mémoire RAM : 3Gigs
Message par b1rd »
Hi and thanks for taking the time to look over my question.
Can somebody please let me know if the latest free version of PhotoFiltre (I think it's release 7.2.0) is compatible with Windows-10 / 64 bit? If not, does anyone know if the portable version would be safe to use instead?
Thanks again,
b1rd
b1rd
Processeur : Intel
Mémoire RAM : 3Gigs
Re: Quick Compatibility Question
Message par b1rd »
I decided to just try it anyhow, and it does seem to work fine. Win-10 does allow you to run it in a compatibility mode, which I did, however it seemed to run fine even before I used that feature. I am talking about the full install, and not the portable version.
I figured I post back in case anybody else wanted to know.
Regards,
b1rd
thanks for this info; i have not windows 10 for the moment :wink:
