64 bits
Petjo10
Version de PhotoFiltre : Studio X 10.10.0
Processeur : i7 -4700HQ 2.4GHZ
Mémoire RAM : 12Gb
64 bits
Message par Petjo10 »
Will there be a 64 bit version of PhotoFiltre ahead?
Re: 64 bits
not for the moment, i have not a 64 bit compiler (I use Delphi 7)
Petjo10
Mémoire RAM : 12Gb
Re: 64 bits
The reason I ask is that I have had problems with that memory sometimes fallen short, but I found this workaround.
http://www.ntcore.com/4gb_patch.php
Regards Peter
Mészáros Tamás
Version de PhotoFiltre : PhotoFiltre Studio 10.13.1
Système d'exploitation : Win 7 Home Premium SP1
Processeur : AMD II X2 Athlon 265 3.3 GHz
Mémoire RAM : 8 Gbyte DDR3 2133 MHz Predator Kingston RAM
Re: 64 bits
Message par Mészáros Tamás »
Petjo10 a écrit :The reason I ask is that I have had problems with that memory sometimes fallen short, but I found this workaround.
Regards Peter
Hi Peter!
I do not think that there will be a 64-bit version. Use free software, which is 64-bit. (Krita https://krita.org/download/krita-desktop/)
Best Regards:
