Hi,
Is there a way to swap the red and blue channels in an image using either Photofiltre 6, or Photofiltre 7?
Thanks,
..... john
Swap red and blue channels
Shinnen
- Mémoire RAM : 1.5 gig
Re: Swap red and blue channels
use the menu Filter > Color > Swap RGB
Shinnen
Hi Antonio,
Thanks for your help. Can you tell me which of the 5 options will swap the red and blue channels?
.... john
.... john
RGB to BGR (R = red, G = green, B = blue)
Shinnen
Thanks Antonio.
..... john
..... john
