Automatic antialiasing in Deform>Trapezoid/Perspective
soapbox
Version de PhotoFiltre : 6.5.3
Système d'exploitation : Win 8.1
Processeur : Intel 5960X 8-core (16-threads)
Mémoire RAM : 64GB DDR4
Message par soapbox »
I noticed that when I use Filter>Deform>Trapezoid/Perspective, the image becomes blurry around edges (like when you select Antialias in Image>Skew).
Is it possible to deform image with trapezoid cleanly without antialias optimiziation?
Re: Automatic antialiasing in Deform>Trapezoid/Perspective
no, bilinéar or bicubic transformation create antialias
